[postgis-devel] [PostGIS] #1741: Build error --with-gui, gtk problem?
PostGIS trac at osgeo.org
Fri Mar 30 05:50:25 PDT 2012
 Reporter:  havatv                       |       Owner:  strk
     Type:  defect                       |      Status:  new
 Priority:  medium                       |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install        |     Version:  2.0.x
 Keywords:  gtk, link, gui, build, make  |
 I am on Debian Lenny, trying to build 2.0.0rc1.
 Building goes fine without {{{--with-gui}}}, but I get errors when using
 {{{--with-gui}}}.
 Here is my configure (apparantly no complaints from configure):
 ./configure --with-raster --with-topology --with-gui --with-
 pgconfig=/usr/local/pgsql/91/bin/pg_config --with-
 geosconfig=/usr/local/bin/geos-config
 Output that seems relevant for GUI:
 GUI: Build requested, checking for dependencies (GKT+2.0)
 checking for pkg-config... /usr/bin/pkg-config
 checking for GTK+ - version >= 2.8.0... yes (version 2.12.12)
 When running make, error message is:
 libtool: link: gcc -g -O2 -fPIC -DPIC -Wall -Wmissing-prototypes shpopen.o
 dbfopen.o getopt.o shpcommon.o safileio.o shp2pgsql-core.o shp2pgsql-gui.o
 pgsql2shp-core.o -o .libs/shp2pgsql-gui ../liblwgeom/.libs/liblwgeom.so
 -L/usr/local/lib
 /usr/local/lib/libgeos_c.so /usr/local/lib/libgeos.so
 /usr/local/lib/libproj.so /usr/lib/libgtk-x11-2.0.so
 /usr/lib/libgdk-x11-2.0.so /usr/lib/libatk-1.0.so
 /usr/lib/libgdk_pixbuf-2.0.so -lm /usr/lib/libpangocairo-1.0.so
 /usr/lib/libpango-1.0.so /usr/lib/libcairo.so /usr/lib/libgobject-2.0.so
 /usr/lib/libgmodule-2.0.so -ldl /usr/lib/libglib-2.0.so
 /usr/local/lib/libiconv.so -L/usr/local/pgsql/91/lib -lpq
 shp2pgsql-gui.o: In function `pgui_create_progress_dialog':
 /home/havatv/src/postgis/postgis-2.0.0rc1/loader/shp2pgsql-gui.c:2614:
 undefined reference to `gtk_dialog_get_content_area'
 shp2pgsql-gui.o: In function `pgui_create_tablechooser_dialog':
 /home/havatv/src/postgis/postgis-2.0.0rc1/loader/shp2pgsql-gui.c:2789:
 collect2: ld returned 1 exit status
 make[1]: *** [shp2pgsql-gui] Error 1
 make[1]: Leaving directory
 `/home/havatv/src/postgis/postgis-2.0.0rc1/loader'
 make: *** [all] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1741>
