[postgis-devel] Confusing output from configure for GDAL?
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Fri Mar 30 06:04:08 PDT 2012
On 30/03/12 13:16, Nicklas Avén wrote:
>> It was caused by something messed up when installing QGIS from repo
>> (with both gdal 1.6 and 1.8 as dependences!)
> BTW, specifying gdal-config didn't help. Configure found gdal-config but
> a few lines below failed with the error message in the link above.
Well this is a new Debian stable installation without any GDAL packages
installed - I compiled GDAL 1.9.0 from source myself. That's the
surprising part, because if it is trying to tell me there is an error
then normally newer versions of libraries have all of the functions
required...
ATB,
Mark.
