[postgis-devel] [PostGIS] #1735: ST_MakeValid: exception on geometry
PostGIS trac at osgeo.org
Fri Mar 30 06:42:01 PDT 2012
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.1
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by strk):
 So, GEOSSymDifference is called by BuildArea and passed the outer rings of
 polygons returned by Polygonize. Supposedly these polygons should all be
 already noded so there would be no reason for the geos noder to complain.
 The offending input to BuildArea is this:
 0105000000050000000102000000050000000000000087523A41000000402C62524100000000B0523A41000000C01E6252410000000084523A41000000C023625241858C4F2488523A4151F8EEAC2562524111A0F52288523A414F50F3AC2562524101020000000300000011A0F52288523A414F50F3AC2562524100A0F52288523A414F50F3AC25625241A871502388523A4158FEF2AC25625241010200000004000000A871502388523A4158FEF2AC25625241A0E6602488523A417108F2AC2562524121E7602488523A417108F2AC25625241A871502388523A4158FEF2AC25625241010200000002000000A871502388523A4158FEF2AC2562524111A0F52288523A414F50F3AC2562524101020000000400000011A0F52288523A414F50F3AC25625241D59FF52288523A414F50F3AC25625241000000007F523A4100000080256252410000000087523A41000000402C625241
 Which is a multilinestring composed by 5 short lines.
 Surprising enough, ST_Relate of the geometry to self has NO BOUNDARY
 INTERSECTION !!
 with inp as ( select
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geometry
 as a ) select st_relate(a, a) from inp;
  1FFFFFFF2
 That's surely a problem !
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1735#comment:12>
