[postgis-devel] [PostGIS] #1735: ST_MakeValid: exception on geometry
PostGIS trac at osgeo.org
Fri Mar 30 08:28:09 PDT 2012
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.1
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by strk):
 Trying to debug the polygonize issue I tried to model the situation I saw
 using intersection matrices into a new simpler input. This is it:
 [[Image(cannot_polygonize.png)]]
 In WKT, it is:
 MULTILINESTRING((0 0, 4 0, 5 3, 4 6),(4 6, 6 6, 5 3, 6 0, 10 0, 5 10, 0
 0),(4 0, 6 0))
 Unfortunately such input results in an EMPTY output from ST_Polygonize,
 which is confusing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1735#comment:17>
