[postgis-devel] [PostGIS] #1742: PostGIS 2.0 alters Z-coordinate
PostGIS trac at osgeo.org
Fri Mar 30 12:11:01 PDT 2012
 Reporter:  pramsey   |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  2.0.x
 Keywords:            |
Comment(by pramsey):
 Mystery solved, it is nothing more mysterious than that PostGIS 2.0 uses
 this as the definition of EPSG:23030:
 +proj=utm +zone=30 +ellps=intl +towgs84=-87,-98,-121,0,0,0,0 +units=m
 +no_defs
 and PostIGIS 1.5 uses this
 +proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
 Hey presto, there's an ellipsoid shift in there, so the X and Y
 coordinates also differ between versions. The killer though is that yes,
 Proj4.8 is now doing a Z-shift too, so the question becomes, what should
 we do with Z?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1742#comment:2>
