[postgis-devel] [PostGIS] #1742: PostGIS 2.0 alters Z-coordinate
PostGIS trac at osgeo.org
Fri Mar 30 12:16:26 PDT 2012
  Reporter:  pramsey   |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  critical  |   Milestone:  PostGIS 2.0.0
 Component:  postgis   |     Version:  2.0.x
Resolution:  invalid   |    Keywords:
Comment(by pramsey):
 Oh, and a note to the original poster, you can get back the "old"
 behaviour (not doing an ellipsoid shift, even though one should be
 applied) by changing the proj4text in your spatial_ref_sys table and
 removing the to_wgs84 parameter.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1742#comment:6>
