[postgis-devel] [PostGIS] #1798: Performance issue with ST_Intersects(geometry, geometry)
PostGIS trac at osgeo.org
Thu May 3 03:24:31 PDT 2012
#1798: Performance issue with ST_Intersects(geometry,geometry)
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by nicklas):
 Ok, I don't know enough about those caching mechanisms, but I will try to
 investigate.
 In this case it is the PostGIS internal rtree(?) algorithm for point in
 polygon tests.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1798#comment:4>
