[postgis-devel] [PostGIS] #1804: README Installation error
PostGIS trac at osgeo.org
Fri May 4 16:35:48 PDT 2012
 Reporter:  jeffmeyer      |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.1
Component:  documentation  |     Version:  2.0.x
 Keywords:  ubuntu         |
 Current doc reads:
 INSTALLATION
 To install PostGIS library and utilities, as postgres run::
   make install
 But, for a Ubuntu clean install of OS, PostGRESQL 9.1, and PostGIS 2.0,
 this yields the following error:
 postgres at jeffmetp:~/postgis-2.0.1SVN$ sudo make install
 [sudo] password for postgres:
 postgres is not in the sudoers file.  This incident will be reported.
 As it is, following the install instructions will cause a fail.
 Not sure what the proper installation instructions should be.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1804>
