[postgis-devel] [PostGIS] #1802: Ensure interruptability of long-running calls
PostGIS trac at osgeo.org
Mon May 7 11:28:59 PDT 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by mcayland):
 What was the resulting effect on performance by adding
 CHECK_FOR_INTERRUPTS to the allocators? Memory allocation is already known
 to be a PostgreSQL performance bottleneck, so it strikes me that this
 could have a significant effect on queries with large datasets/long query
 times. Can you provide the before and after numbers for a test query on a
 reasonably-sized dataset (several million records)?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1802#comment:5>
