[postgis-devel] [PostGIS] #1806: Extremely slow and CPU-intensive ST_MakeValid (ST_BuildArea) case
PostGIS trac at osgeo.org
Tue May 8 09:49:14 PDT 2012
 Reporter:  strk     |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  high     |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by strk):
 r9729 sorts polygonized output items by number of points, slighly
 improving performances.
 A reduction of the offending input, with number of holes cut from 4000+ to
 only 500 showed a speedup from 12 seconds to 9 seconds. Not such a big
 improvement.
 Another thing to look at is short-circuits in GEOSSymDifference (none seen
 as of 3.3.3)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1806#comment:10>
