[postgis-devel] [PostGIS] #1807: ERROR: Unknown WKB type (13)! Full WKB type number was (13)
PostGIS trac at osgeo.org
Wed May 9 09:40:12 PDT 2012
 Reporter:  hsingh19       |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  high           |   Milestone:  PostGIS 2.0.1
Component:  postgis        |     Version:  2.0.x
 Keywords:  Full WKB type  |
Comment(by pramsey):
 Like I said, a small test data file that shows up the problem would be
 super. Make a tiny table (select * from something limit 10) on your 1.5
 instance, dump it, confirm it fails to load on your 2.0 instance, then
 attach it to this ticket.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1807#comment:4>
