[postgis-devel] [PostGIS] #1808: [raster] Raster importation creates gaps and corrupted data
PostGIS trac at osgeo.org
Wed May 9 16:29:14 PDT 2012
 Reporter:  molgor   |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 Hello everyone,
 I have imported raster data to postgis 2.0 with '''raster2pgsql'''.
 Loaded that table into postgis using the ''add raster postgis'' plugin and
 got an almost useless raster.
 Firstly I thought it could be a QGIS problem, but after quering the
 ST_Value of that dataset on a point where the gap occurs, it returns an
 empty value (not the nodata value).
 I tried to import the raster with the 'out-db' option with similar
 results.
 I exported the raster table on a png file and the gaps persists.
 The png file is attached to this ticket.
 The original image is 2.1GB in geotif format
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1808>
