[postgis-devel] [PostGIS] #1808: [raster] Raster importation creates gaps and corrupted data
PostGIS trac at osgeo.org
Thu May 10 09:58:42 PDT 2012
 Reporter:  molgor  |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  high    |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
Comment(by molgor):
 gdal version is: 1.9.0
 Postgres and Postgis versions are:
 incendios=# select version();
                                            version
  PostgreSQL 9.1.3 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
 (1 row)
 incendios=# select postgis_version();
             postgis_version
  2.0 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
 (1 row)
 The three packages were build from source
 Thank you for your quick response
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1808#comment:6>
