[postgis-devel] [PostGIS] #1808: [raster] Raster importation creates gaps and corrupted data
PostGIS trac at osgeo.org
Thu May 10 13:58:02 PDT 2012
 Reporter:  molgor  |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  high    |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
Comment(by dustymugs):
 The vrt that I attached is one generated by raster2pgsql when it is
 processing the source raster.  Normally it is only in memory (not a file)
 but I tweaked the raster2pgsql loader code to spit out the VRT as a file
 so that I could inspect it.
 After doing a debug build of PostGIS and testing the loader, I can't find
 any problems with the entire loading process.  Testing other tiles...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1808#comment:12>
