[postgis-devel] [PostGIS] #1802: Ensure interruptability of long-running calls
PostGIS trac at osgeo.org
Sat May 12 07:57:33 PDT 2012
 Reporter:  strk     |       Owner:  strk
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by mcayland):
 Well on the plus side, hopefully the check for InterruptPending should be
 reasonably lightweight. I'd just go for an index && join with
 ST_Contains() returning around 100,000 points and see what results you get
 before and after.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1802#comment:10>
