[postgis-devel] [PostGIS] #1812: cunit failure on build area
PostGIS trac at osgeo.org
Sun May 13 18:09:04 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  trunk
 Keywords:  mingw    |
 strk,
 This is failing on my mingw32 chain.
 Do your build area changes rely on new GEOS changes.  Haven't recompiled
 my GEOS 3.3.4dev (r3614) yet (and that is about a 2 weeks old I think).
 Suite: buildarea
   Test: buildarea1 ... passed
   Test: buildarea2 ...  Failure at cu_buildarea.c:94
  Exp: POLYGON((0 0,0 10,10 10,20 10,20 0,10 0,0 0))
  Obt: POLYGON((10 10,20 10,20 0,10 0,0 0,0 10,10 10))
 FAILED
     1. cu_buildarea.c:94  - 0
 Haven't tested yet on my ming64 chain.  This is r9732
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1812>
