[postgis-devel] [PostGIS] #1812: cunit failure on build area
PostGIS trac at osgeo.org
Mon May 14 00:59:29 PDT 2012
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  trunk
 Keywords:  mingw    |
Comment(by strk):
 I've _added_ the tests first in r9730, and only changed the expected
 result in r9731 to follow the new algorithm.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1812#comment:4>
