[postgis-devel] [PostGIS] #1812: cunit failure on build area
PostGIS trac at osgeo.org
Mon May 14 01:08:12 PDT 2012
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  trunk
 Keywords:  mingw    |
Comment(by strk):
 I could reproduce a failure on a 32bit system with non-updated GEOS, but
 only with buildarea7:
 Suite: buildarea
   Test: buildarea1 ... passed
   Test: buildarea2 ... passed
   Test: buildarea3 ... passed
   Test: buildarea4 ... passed
   Test: buildarea4b ... passed
   Test: buildarea5 ... passed
   Test: buildarea6 ... passed
   Test: buildarea7 ...  Failure at cu_buildarea.c:310
  Exp: MULTIPOLYGON(((80 0,80 70,110 70,110 0,80 0),(90 60,90 50,100 50,100
 60,90 60)),((20 20,20 30,20 50,30 50,30 30,30 20,20 20)),((0 0,0 70,70
 70,70 0,0 0),(10 10,40 10,40 60,10 60,10 10),(50 20,60 20,60 40,60 60,50
 60,50 40,50 20)))
  Obt: GEOMETRYCOLLECTION(POLYGON((80 0,80 70,110 70,110 0,80 0),(90 60,90
 50,100 50,100 60,90 60)),LINESTRING(60 40,50 40),POLYGON((20 20,20 30,20
 50,30 50,30 30,30 20,20 20)),POLYGON((0 0,0 70,70 70,70 0,0 0),(10 10,40
 10,40 60,10 60,10 10),(50 20,60 20,60 40,60 60,50 60,50 40,50 20)))
 FAILED
     1. cu_buildarea.c:310  - 0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1812#comment:5>
