[postgis-devel] [PostGIS] #1816: SVN updates applied in PostgreSQL 9+
PostGIS trac at osgeo.org
Mon May 14 15:52:54 PDT 2012
 Reporter:  darkblueb    |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS Future
Component:  postgis      |     Version:  2.0.x
 Keywords:               |
 currently, to build and test new code from topology svn, either tricky sym
 links or a complete dump and reload of the test database appear to be
 necessary when using CREATE EXTENSION sort of libraries, such as
 postgis_topology.
 wouldn't it be better to have a way to cleanly reload topology after
 building and installing? same for other EXTENSION based additions, most
 likely...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1816>
