[postgis-devel] [PostGIS] #1819: [raster] floating point issues with ST_World2RasterCoordX and ST_World2RasterCoordY
PostGIS trac at osgeo.org
Tue May 15 14:38:38 PDT 2012
 Reporter:  dustymugs  |       Owner:  dustymugs
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.0
Component:  raster     |     Version:  trunk
 Keywords:             |
 For some rasters, I'm finding that the if I pass the upper left corner of
 a raster to ST_World2RasterCoord(X|Y), the function returns zero (0)
 instead of one (1).  After doing some digging, the problem arises from the
 computation taking place in plpgsql.
 Testing a plpgsql function calling the underlying C function
 rt_raster_geopoint_to_cell() that does the same process, the correct
 answer is consistently provided.
 I'll try to post a concise example once I find one.
 This should be backported to 2.0.x...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1819>
