[postgis-devel] [PostGIS] #1820: Can't compile against 9.2 beta1
PostGIS trac at osgeo.org
Tue May 15 23:48:55 PDT 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 This file exists in my 8.4-92 includes so I presume it would be safe to
 add without a conditional if PG92?
 If I add this include to the postgis/lwgeom_triggers.c it gets further and
 then breaks at
 long_xact.c: In function `check_authorization':
 long_xact.c:85: error: dereferencing pointer to incomplete type
 long_xact.c:102: error: dereferencing pointer to incomplete type
 which I presume has the same issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1820#comment:2>
