[postgis-devel] [PostGIS] #1825: containsproperly: Conditional jump or move depends on uninitialised value(s)
PostGIS trac at osgeo.org
Wed May 16 10:17:57 PDT 2012
value(s)
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 Running one of the tests in our regression suite under valgrind gives a
 conditional jump depending on uninitialized error:
 The query:
 SELECT c, ST_ContainsProperly(ply, pt) FROM ( VALUES
 ('containsproperly099', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', 'POINT(5
 5)'), ('containsproperly103', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))',
 'POINT(0 5)'), ('containsproperly104', 'POLYGON((0 0, 0 10, 10 10, 10 0, 0
 0))', 'POINT(0 12)')) AS v(c,ply,pt);
 Note that you _need_ 3 records in there, or the error doesn't show up.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1825>
