[postgis-devel] [PostGIS] #1824: Installation on windows 64 failed
PostGIS trac at osgeo.org
Wed May 16 10:59:17 PDT 2012
 Reporter:  pierrevandelaar        |       Owner:  robe
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.1
Component:  build/upgrade/install  |     Version:  2.0.x
 Keywords:                         |
Comment(by robe):
 additional note -- if you are missing libiconv-2.dll in postgresql/9.1/bin
 then that could be the problem.  You should be able to just copy the one
 from postgisgui into the bin folder.  We didn't bother packaging that one
 since EnterpriseDb builds we were targetting already had that file in bin.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1824#comment:2>
