[postgis-devel] No CFLAGS in postgis/Makefile.in
Paul Ramsey pramsey at opengeo.org
Thu May 17 06:21:36 PDT 2012
As discussed on IRC, both intentional and not new. We inherit our
build flags from PostgreSQL with PGXS. If you want debug, configure
your PostgreSQL with --enable-debug, then reconfigure your PostGIS.
P.
On Thu, May 17, 2012 at 3:01 PM, Sandro Santilli <strk at keybit.net> wrote:
> I've noticed, by reading valgrind reports, that while code in liblwgeom/
> contains debugging symbols the code in postgis/ does not.
> Indeed there's no "-g" in the build line, nor any CFLAGS defined
> in postgis/Makefile.in. Is that intentional ? Is that new ?
> --strk;
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
