[postgis-devel] [PostGIS] #1287: Drop of "gist_geometry_ops" broke a few clients
PostGIS trac at osgeo.org
Fri May 18 04:40:58 PDT 2012
  Reporter:  strk     |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  wontfix  |    Keywords:  history
Comment(by robe):
 Dane,
 Not that I would be of much, help, but I can try.  What sort of problems
 are you running into compiling the latest osm2pgsql code base on windows?
 Admittedly I've never tried compiling osm2pgsql on windows -- just always
 used your binaries :)
 BTW Paul fixed the srid missing entry for 2.0 in #1805 so hopefully
 shouldn't be necessary for users to have to load that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1287#comment:9>
