[postgis-devel] [PostGIS] #1830: pgsql2shp fix for "XInvalid endian flag value encountered" on PostgreSQL 9.2
PostGIS trac at osgeo.org
Sat May 19 17:10:10 PDT 2012
9.2
 Reporter:  dfuhry2  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.1
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
 pgsql2shp gives "Invalid endian flag value encountered." error on
 PostgreSQL 9.2 due to its expecting bytea_output to be in 'escape' format.
 At some point PostgreSQL changed the default bytea output format from
 'escape' to 'hex'.
 Attached patch sets server bytea_output to 'escape' while connecting,
 fixing the problem.
 $ pgsql2shp ...
 Initializing...
 Done (postgis major version: 2).
 Output shape: Polygon
 Dumping: XInvalid endian flag value encountered.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1830>
