[postgis-devel] [PostGIS] #1831: ability to separate user defined spatial_ref_sys from installed
trac at osgeo.org
Sun May 20 11:16:08 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: 2.0.x
Keywords: |
I thought we had this in our tracker already, but perhaps we only
discussed it.
spatial_ref_sys is a semi-postgis / semi user-defined.
We have been battling the issue of how to separate these two so that
upgrade is a bit less painless for as far back as I can remember. It
wasn't so much of an issue when we had fewer users but now is becoming
more of a major one.
1) strk proposed a while back making it a view and having two tables:
spatial_ref_sys_master, spatial_ref_sys_custom and then spatial_ref_sys
would be the union of the 2 and people would put all their custom entries
in spatial_ref_sys_custom
2) I didn't like that idea too much because it might break apps and
proposed we just have a bit switch instead where we would tag all the ones
we input is postgis installed. And the remaining ones we would default
user input to true so in theory nothing would change except for people
being lazy and doing an insert like
INSERT INTO spatial_ref_sys VALUES (... without qualifying the tables.
strk also pointed out it might break the postgis_restore which assumes the
structure.
3) I have a third idea which is a bit of a morph of the two. Keep
spatial_ref_sys as a table, but add another table for custom spatial
ref_sys records. Have custom spatial_ref_sys inherit from spatial_ref_sys
but put in a DO INSTEAD OF trigger in spatial_ref_sys that we would put in
after we have inserted all our records. The do instead would push updates
to the custom_spatial_ref_sys
(It's really a revision of strk's #1)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1831>
