[postgis-devel] [PostGIS] #1830: pgsql2shp fix for "XInvalid endian flag value encountered" on PostgreSQL 9.2
PostGIS trac at osgeo.org
Sun May 20 15:00:00 PDT 2012
9.2
  Reporter:  dfuhry2        |       Owner:  pramsey
      Type:  defect         |      Status:  reopened
  Priority:  high           |   Milestone:  PostGIS 2.0.1
 Component:  loader/dumper  |     Version:  2.0.x
Resolution:                 |    Keywords:
Comment(by robe):
 Yah I'll double-check but I don't recall having issues dumping and viewing
 my shape file in ArcGIS, QGIS, or OpenJump.  I'll have to double-check to
 make sure I didn't have an encoding setting on, but I don't think I did
 last I tried.  Mark is right this bytea_output change happened in 9.0 not
 9.2.  So this could be possibly something else introduced in 9.2.
 We should at the very least have in our make check routine a test that
 dumps out and then reloads the dumped shape file.  I forget if any of our
 tests does that.
 at anyrate, Paul you need to revert that patch since as Mark says -- it
 will break 8.4 support which we have to support in 2.0.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1830#comment:3>
