[postgis-devel] [PostGIS] #1824: Installation on windows 64 failed
trac at osgeo.org
Mon May 21 08:01:09 PDT 2012
Reporter: pierrevandelaar | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: build/upgrade/install | Version: 2.0.x
Keywords: |
Comment(by robe):
You might want to just upgrade to 9.1.3 and that might fix your issue. I
think between 9.1.2 and 9.1.3 they changed names they started using
libxml2-2 instead of libxml2. Anyrate you should upgrade regardless since
you aren't runnign the latest micro.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1824#comment:5>
