[postgis-devel] [PostGIS] #1824: Installation on windows 64 failed
PostGIS trac at osgeo.org
Tue May 22 00:25:29 PDT 2012
  Reporter:  pierrevandelaar        |       Owner:  robe
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.1
 Component:  build/upgrade/install  |     Version:  2.0.x
Resolution:  fixed                  |    Keywords:
Changes (by pierrevandelaar):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 I upgraded to PostgresQL 9.1.3. The installation of PostGIS 2.0.0 then
 went fine.
 Problem solved ;-)
 Maybe add a note to the installation instructions that you need 9.1.3....
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1824#comment:7>
