[postgis-devel] [PostGIS] #1832: Crash when updating GIST index on geography column
PostGIS trac at osgeo.org
Tue May 22 02:06:40 PDT 2012
  Reporter:  raduilie  |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  high      |   Milestone:  PostGIS 1.5.4
 Component:  postgis   |     Version:  1.5.X
Resolution:  fixed     |    Keywords:  crash gist geography
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => fixed
Comment:
 You were right, introducing the fix for empties also introduced this
 error, but curiously only in 1.5. The 2.x branches had the tests in the
 safe order. Fixed in 1.5 at r9776.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1832#comment:1>
