[postgis-devel] [PostGIS] #1751: [raster] ST_NearestValue
PostGIS trac at osgeo.org
Tue May 22 10:34:45 PDT 2012
  Reporter:  dustymugs    |       Owner:  dustymugs
      Type:  enhancement  |      Status:  closed
  Priority:  medium       |   Milestone:  PostGIS 2.1.0
 Component:  raster       |     Version:  trunk
Resolution:  fixed        |    Keywords:  history
Comment(by pracine):
 Replying to [comment:6 dustymugs]:
 > Correct, if exclude_nodata_value = FALSE there is no difference between
 ST_NearestValue and ST_Value.  There would be no performance difference in
 that situation.
 Then I don't see the need for all the variants taking the
 exclude_nodata_value parameter. If you want this to be false use
 ST_Value...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1751#comment:7>
