[postgis-devel] [PostGIS] #1819: [raster] floating point issues with ST_World2RasterCoordX and ST_World2RasterCoordY
PostGIS trac at osgeo.org
Wed May 23 10:28:55 PDT 2012
  Reporter:  dustymugs  |       Owner:  dustymugs
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.0.1
 Component:  raster     |     Version:  2.0.x
Resolution:  fixed      |    Keywords:  history
Comment(by pracine):
 Did you make sure that only one of the upper left and the lower right
 corner (and not both) are converted to an actual raster coordinate. i.e.
 If the upper left corner returns 1 then the lower right corner should
 return width + 1. Otherwise, from tile to tile, you fall into
 inconsistencies.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1819#comment:4>
