[postgis-devel] [PostGIS] #1841: ST_Distance on PostGIS 2.0 is prohibitively slow
PostGIS trac at osgeo.org
Wed May 23 11:21:41 PDT 2012
 Reporter:  andrewxhill         |       Owner:  pramsey
     Type:  enhancement         |      Status:  new
 Priority:  medium              |   Milestone:  PostGIS 2.1.0
Component:  postgis             |     Version:  2.0.x
 Keywords:  st_distance, speed  |
 Running a query to get a pairwise distance calculation for a table takes
 very long. I'm using this to generate a distance matrix for use in R.
 An example query,
 select a.a as g1, b.a as g2, st_distance(a.g, b.g) as d from a join a b on
 a.a<b.a
 Can take minutes on the following data,
 st_distance - no spheroids
 623 polygons with an average of 625 points each (single ring, shell only)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1841>
