[postgis-devel] regress!
Sandro Santilli strk at keybit.net
Wed May 23 12:48:01 PDT 2012
On Wed, May 23, 2012 at 09:37:09PM +0200, Olivier Courtin wrote:
> On May 23, 2012, at 8:24 PM, Sandro Santilli wrote:
> Hi Sandro,
> > On Tue, May 22, 2012 at 06:14:58PM +0200, Olivier Courtin wrote:
> >> On May 22, 2012, at 5:15 PM, Paul Ramsey wrote:
> >>> The docs now have an entry for a function signature that ST_AsGML
> >>> doesn't support anymore, so regression still breaks when the comments
> >>> are loaded...
> >> As r9785 it should be better,
> >> Wrong SQL prototype in postgis.sql.in.c
> >> My fault, i committed yesterday night, a bit too early...
> > It still fails for me at r9810 (trunk):
> > psql:.../regress/00-regress-install/share/contrib/postgis/postgis_comments.sql:364: ERROR:  function st_asgml(integer, geography, integer, integer, text, text) does not exist
> > Did you fix in 2.0 branch only ?
> It's a new feature, so only played in trunk
> With a fresh install (r9810), i don't face this issue:
> svn checkout http://svn.osgeo.org/postgis/trunk postgis-svn
> cd postgis-svn/
> sh autogen.sh
> ./configure --without-topology --without-raster
> cd regress/
> export PGUSER=postgres
> make check
> Something i missed, or you still have old code mixed ?
Uhm... do you have the comments built ? Look in
if you do, see line 364.
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
