[postgis-devel] Installed GEOS libs on Ubuntu 12.04
maplabs at light42.com maplabs at light42.com
Wed May 23 23:37:49 PDT 2012
Hi All -  if GEOS is built from trunk and installed on a new Ubuntu install,
then the package manager is used to install
         libgdal1-1.7.0 libgdal1-dev libgeos-3.2.2 libgeos-c1  libgeos-dev
the resulting /usr/local/lib looks as follows:
dbb at r900:~$ ls -l /usr/local/lib
total 74144
drwxr-xr-x 2 root root      4096 May 22 20:12 geos
-rwxr-xr-x 1 root root  18493010 May 22 20:11 libgeos-3.4.0dev.so
-rw-r--r-- 1 root root  50322836 May 22 20:12 libgeos.a
-rw-r--r-- 1 root root   2239188 May 22 20:12 libgeos_c.a
-rwxr-xr-x 1 root root       979 May 22 20:12 libgeos_c.la
lrwxrwxrwx 1 root root        18 May 22 20:12 libgeos_c.so ->
libgeos_c.so.1.8.0
lrwxrwxrwx 1 root root        18 May 22 20:12 libgeos_c.so.1 ->
libgeos_c.so.1.8.0
-rwxr-xr-x 1 root root   1051542 May 22 20:12 libgeos_c.so.1.8.0
-rwxr-xr-x 1 root root       956 May 22 20:11 libgeos.la
lrwxrwxrwx 1 root root        19 May 22 20:11 libgeos.so ->
libgeos-3.4.0dev.so
-rw-r--r-- 1 root root   2519854 May 22 20:13 libproj.a
-rwxr-xr-x 1 root root       943 May 22 20:13 libproj.la
lrwxrwxrwx 1 root root        16 May 22 20:13 libproj.so -> libproj.so.0.7.0
lrwxrwxrwx 1 root root        16 May 22 20:13 libproj.so.0 -> libproj.so.0.7.0
-rwxr-xr-x 1 root root   1261167 May 22 20:13 libproj.so.0.7.0
drwxr-xr-x 2 root root      4096 May 22 20:13 pkgconfig
drwxrwsr-x 4 root staff     4096 May 21 11:31 python2.7
drwxrwsr-x 3 root staff     4096 May 23 23:27 R
Q. Is this a useable state of affairs?
also, will PostGIS built from source against libgeos-3.4.0dev remain
unaffected?
Brian Hamlin
GeoCal-ish
OSGeo California Chapter
415-717-4462 cell
