[postgis-devel] [PostGIS] #1848: raster regress failure on mingw mapalgebraexpr, rt_clip
PostGIS trac at osgeo.org
Wed May 30 20:42:56 PDT 2012
 Reporter:  robe    |       Owner:  pracine
     Type:  defect  |      Status:  new
 Priority:  medium  |   Milestone:  PostGIS 2.0.1
Component:  raster  |     Version:  2.0.x
 Keywords:          |
 Not sure how long this has been an issue.  I got halted checking because
 of the build area regresses and was too lazy to move on.
 Anyrate on my pg 8.4 mingw32bit gcc 3.4.5, I am getting regression
 failures.
  rt_mapalgebraexpr .. failed (diff expected obtained:
 /tmp/pgis_reg/test_41_diff)
  rt_mapalgebrafct .. ok
  rt_mapalgebraexpr_2raster .. ok
  rt_mapalgebrafct_2raster .. ok
  drop_rt_mapalgebra_test .. ok
  create_rt_mapalgebrafctngb_test .. ok
  rt_mapalgebrafctngb .. ok
  rt_mapalgebrafctngb_userfunc .. ok
  drop_rt_mapalgebrafctngb_test .. ok
  rt_reclass .. ok
  rt_resample .. ok
  rt_asraster .. ok
  rt_intersection .. ok
  rt_clip .. failed (diff expected obtained: /tmp/pgis_reg/test_54_diff)
  create_rt_gist_test .. ok
  rt_above .. ok
  rt_below .. ok
  rt_contained .. ok
  rt_contain .. ok
  rt_left .. ok
  rt_overabove .. ok
  rt_overbelow .. ok
  rt_overlap .. ok
  rt_overleft .. ok
  rt_overright .. ok
  rt_right .. ok
  rt_same .. ok
  drop_rt_gist_test .. ok
  rt_spatial_relationship .. ok
  rt_intersects .. ok
  rt_samealignment .. ok
  bug_test_car5 .. ok
  tickets .. ok
  loader/Basic ...... ok
  loader/BasicCopy ...... ok
  loader/Tiled10x10 ..... ok
  loader/Tiled10x10Copy ..... ok
  uninstall ... ok (3699)
 Run tests: 78
 Failed: 2
 using gdal 1.9.0.  I have to test the others to make sure its not just
 something screwy with my envs.
 See attached files
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1848>
