[postgis-devel] [PostGIS] #2076: Loading logic for tiger 2012
PostGIS trac at osgeo.org
Fri Nov 2 23:23:31 PDT 2012
 Reporter:  robe            |       Owner:  robe
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.1.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Things were looking promising for a bit simply changing the years and
 paths in loader_variables table to 2012 almost worked.
 Seems they've changed structures yet again.  I loaded nations table with
 script, no problem.
 When got to faces, (loading MA, DC), things went downhill when got to
 faces
 Get error:
 similar to this report:
 http://lists.osgeo.org/pipermail/postgis-users/2012-November/035638.html
 I script works fine with 2011 data folder, but when switch to 2012 then I
 get error at faces.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2076#comment:1>
