[postgis-devel] [PostGIS] #2076: Loading logic for tiger 2012
PostGIS trac at osgeo.org
Sat Nov 3 11:16:36 PDT 2012
 Reporter:  robe            |       Owner:  robe
     Type:  enhancement     |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.1.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:  history         |
Changes (by robe):
  * keywords:  => history
Comment:
 Okay I think I've resolved this r10633 - r10634.  I created a separate
 file tiger_loader_2012.sql and changed the create new scripts to use that
 instead.  I think that will work for 2011 as well, but won't merge until
 I've tested with 2011.
 The folder is now misnamed so will rename before I close this ticket and
 also need to update the readme and docs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2076#comment:2>
