[postgis-devel] [PostGIS] #2081: installation from source fails
PostGIS trac at osgeo.org
Sun Nov 4 11:07:35 PST 2012
 Reporter:  brushtyler  |       Owner:  pramsey
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.2
Component:  postgis     |     Version:  trunk
 Keywords:              |
 I've built postgis from source, but installing it I get the following
 error message:
 /usr/bin/install -c -m 644 ./sql/postgis--2.0.0--2.1.0SVN.sql
 ./sql/postgis--2.0.1--2.1.0SVN.sql ./sql/postgis--2.1.0SVN--
 2.1.0SVNnext.sql ./sql/postgis--2.1.0SVNnext--2.1.0SVN.sql ./sql/postgis--
 2.1.0SVN.sql ./sql/postgis--unpackaged--2.1.0SVN.sql ./sql/postgis--
 2.1.0SVN.sql '/usr/local/pgsql/share/extension/'
 /usr/bin/install: will not overwrite just-created
 `/usr/local/pgsql/share/extension/postgis--2.1.0SVN.sql' with
 `./sql/postgis--2.1.0SVN.sql'
 make[2]: Error 1
 I'm on Ubuntu 11.04, trying to install PostGIS trunk.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2081>
