[postgis-devel] [PostGIS] #1980: Allow overriding mathml location
PostGIS trac at osgeo.org
Sun Nov 4 23:24:29 PST 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.2
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by strk):
 Of course it would be better to do it offline, but the setup depends on
 the system.
 I know apt-based packaging system have a "docbook-mathml" and a "w3-dtd-
 mathml" package
 and I think someone mentioned a systemwide configuration instructing
 docbook about which online url to map to which local file. It's not really
 something that can easily be done at the postgis configuration level
 because it's the DTD (or schema) themselves referencing other online
 resources, so even if you have your local mathml file it still references
 online resources, and the only way to prevent xsltproc from fetching those
 resources online is by passing it a mapping to local filesystem files.
 Sorry for the oververbose braindump.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1980#comment:9>
