[postgis-devel] [PostGIS] #1999: Crash on LINESTRING with one point
PostGIS trac at osgeo.org
Wed Nov 7 15:37:28 PST 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
Comment(by realityexists):
 Not sure how I could get a stack trace on Windows, even if I had gdb
 installed, given that there are no PDB files in the Windows PostGIS build.
 I don't have x64 Linux available, only x86 with PostgreSQL 9.2 and it
 doesn't happen there.
 Yes, it does require the fancy function to repro - simply running the
 SELECT returns the expected error every time, no crashes. One slightly
 strange thing I've noticed is that there is sometimes an extra newline
 after the hint, ie.
 ERROR:  geometry requires more points
 LINE 1: SELECT 'LINESTRING(0 0)'::geometry;
 HINT:  "LINESTRING(0 0)" <-- parse error at position 16 within geometry
 <phantom blank line>
 Probably unrelated, but that extra new line shows up maybe 1-2 times out
 of 10 attempts. That's running from pgAdmin, so possibly a pgAdmin issue.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1999#comment:8>
