[postgis-devel] [PostGIS] #1999: Crash on LINESTRING with one point
PostGIS trac at osgeo.org
Thu Nov 8 00:07:12 PST 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
Comment(by robe):
 I'll try to capture in gdb later tomorrow and also see if it just happens
 in EDB or happens under mingw64 compiled postgresql as well.
 I've run into a lot of cases that work fine in ming environment and crash
 in EDB (for the 64-bit) and was meaning to enable testing on EDB as well
 but then when manually retest on EDB work fine.  I haven't bothered
 setting up EDB testing because Winnie's EDB screaming would drive pramsey
 insane.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1999#comment:9>
