[postgis-devel] XML Prefixes
Oliver Courtin olivier.courtin at oslandia.com
Sun Nov 11 16:10:13 PST 2012
Le 12 nov. 2012 à 01:00, Paul Ramsey a écrit :
Hi Paul,
>> I just sat down at my desktop computer for the first time in a while
>> and built 1.5 and made check on it, and got errors in the in_gml
>> regression.
>> It looks like libxml2 2.8.0 is returning "gml:Point" as the tag name
>> for a "Point" and not returning anything in the namespace slot. I'm
>> upgrading my macports on the laptop now to see if the problem happens
>> on all my machines, but I'm wondering if anyone else has seen in_gml
>> regressions starting to fail with newer versions of libxml2?
>> I haven't found any way to force libxml2 to recognize and strip the
>> namespace prefix either, it's a stumper.
> Confirmed, I've not got it broken on both my laptop and desktop. The
> common element seems to be moving to libxml2 2.8.0
I also have the same kind of regression issue with  1.5 branch and libxml2 2.8.0
(didn't yet try, but guess it should be the same for 2.0 branch)
Need to explore it further to look for a solution/workaround...
O.
