[postgis-devel] [PostGIS] #2092: libxml2.8.0 namespace prefix issue
PostGIS trac at osgeo.org
Sun Nov 11 17:51:54 PST 2012
 Reporter:  colivier  |       Owner:  colivier
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.2
Component:  postgis   |     Version:  2.0.x
 Keywords:            |
Comment(by pramsey):
 The problem is is_kml_namespace (probably is_gml_namespace has similar
 issues, they just aren't tested as much) testing the name space element,
 which looks like this:
 $11 = {
   next = 0x0,
   type = XML_NAMESPACE_DECL,
   href = 0x0,
   prefix = 0x100a038e0 "kml",
   _private = 0x0,
   context = 0x0
 Note that (a) it exists and (b) is has a null href. The routine expects
 that if you have an ns element, it's got everything, and that if you don't
 have one, you can assume none was declared. I guess the old routine
 stripped the prefixes without populating the name space elements, fun.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2092#comment:3>
