[postgis-devel] [PostGIS] #1987: Results given by ST_Simplify inconsistent between PostGIS 1.5.2 and 2.0.1
PostGIS trac at osgeo.org
Mon Nov 12 11:25:51 PST 2012
 Reporter:  ChrisInCambo  |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  high          |   Milestone:  PostGIS 2.1.0
Component:  postgis       |     Version:  2.0.x
 Keywords:                |
Changes (by robe):
  * milestone:  PostGIS 2.0.2 => PostGIS 2.1.0
Comment:
 strk I'm changing this back to 2.1 until you come up with a better
 argument why you think this can be allowed in a micro :)
 Even the -- let's change the behavior back to 1.5 behavior is borderline
 acceptable because stark behavior changes between majors are always
 allowed (would require a document fix), but a regression back in a micro
 is technically only allowed if you feel the new behavior is a bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1987#comment:15>
