[postgis-devel] [PostGIS] #1984: geography_btree.c: array subscript is above array bounds [-Warray-bounds]
PostGIS trac at osgeo.org
Sat Nov 17 16:35:06 PST 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by pramsey):
 The code itself is perfectly legal and good and well tested, it's just a
 compiler warning. Changing the code is dangerous, since it works fine.
 Using some other C construct to express the intent might quiet the warning
 on the newer gcc compilers but break our compilation on other ones.
 Definitely a 2.1 thing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1984#comment:4>
