[postgis-devel] [PostGIS] #2099: GEOSOffsetCurve: IllegalArgumentException: RobustDeterminant encountered non-finite numbers
PostGIS trac at osgeo.org
Sun Nov 18 23:49:48 PST 2012
non-finite numbers
 Reporter:  mamay           |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.1.0
Component:  postgis         |     Version:  2.0.x
 Keywords:  ST_OffsetCurve  |
Comment(by robe):
 Mamay,
 Can you also provide us with version of PostgreSQL you are running on
 each:
 {{{ SELECT version();}}}
 I've seen different behaviors on different PostgreSQL versions too, though
 I haven't had a chance to test this particular example you have.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2099#comment:1>
