[postgis-devel] [PostGIS] #1987: Results given by ST_Simplify inconsistent between PostGIS 1.5.2 and 2.0.1
PostGIS trac at osgeo.org
Mon Nov 19 01:54:26 PST 2012
 Reporter:  ChrisInCambo  |       Owner:  pramsey
     Type:  defect        |      Status:  new
 Priority:  blocker       |   Milestone:  PostGIS 2.0.2
Component:  postgis       |     Version:  2.0.x
 Keywords:                |
Comment(by strk):
 ChrisInCambo, could you tell us more about your dataset and requirements ?
 Do you think a LINESTRING composed by a single segment of length X should
 also be set to NULL when the given tolerance is >X ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1987#comment:22>
