[postgis-devel] [PostGIS] #2102: Create separate json build for 2.0 and 2.1 for winnie
PostGIS trac at osgeo.org
Tue Nov 20 13:57:58 PST 2012
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  Management 2.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
 Just realized why winnie goes nuts when both 2.0 and 2.1 are changed.
 Duh.  On windows I have as par tof my buuild script to hack the json
 configuration because of the boolean bug.
 I have described in: http://trac.osgeo.org/postgis/wiki/DevWikiWinMingW64
 which requires a different sate on configure than for compile.
     Open up /c/projects/json-c/rel-0.9/include/json/json_object.h
     remark out line 32 that reads
         typedef int boolean
     so it should now read
         /** typedef int boolean; **/
 Since I'm using the same json build for both 2.0 and 2.1 every once in a
 while the two overwrite the configure mid build screwing up the other.
 Though I thought I had them chained so they would never run at the same
 time, I guess I don't except for within the same branch.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2102>
